Re: Re: 1456 Transmission
Posted by John on February 09, 2001 at 15:21:16 from (152.163.206.176):
In Reply to: Re: 1456 Transmission posted by Jim on February 09, 2001 at 07:29:52:
Jim, thanks for the quick response. It's jumping out of gear. At first it only jumped out of second now it jumps out of 1st, but only when I am in high range and under heavy load.
Post A Followup
: Re: Re: Re: 1456 Transmission
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
