Re: can't get seal off counter shaft of SM
Posted by Haas on February 09, 2001 at 16:23:11 from (129.37.117.84):
In Reply to: can't get seal off counter shaft of SM posted by Joe Berendzen on February 09, 2001 at 08:17:11:
As Red says, it is threaded. Unscrews counterclockwise. I'd suggest putting the tractor in gear and lock the brakes. Then put a bar in the slot of the coupling half and apply leverage in CC direction. If that does not work, then apply a hammer to the bar. The other coupling half on the lift all is also threaded and unscrew cc. These things can really get jammed on tight!
Post A Followup
: Re: Re: can't get seal off counter shaft of SM
