Dirt dobbers can build a nest in a cracked eggshell !
Posted by jiM on February 09, 2001 at 18:31:22 from (63.24.182.61):
General Winter maintenance made me aware of a darned ol Sumertime pest today tailwaggers(dirtdobbers). Those goobers had built nest(s)
in the gear box housing between the tranny and the clutch. I noticed this when I removed the screen to clean the pto shaft and tranny gears. Ahah! the little squirts got in through the hydraulic hookups I guess. Y'all got a remedy for this? Except pluggin' all the holes?
Post A Followup
: Re: Dirt dobbers can build a nest in a cracked eggshell !
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
