Re: H oil pan leak
Posted by Bob M on February 11, 2001 at 08:01:35 from (66.24.99.103):
In Reply to: H oil pan leak posted by Joe on February 10, 2001 at 22:25:42:
Braze or solder will work fine. But I've had excellent luck using JB Weld to repair stuff like this. Get the inside of the pan around the petcock scrupulously clean (light sandblast if you can then degrease) - you'll probably find a small crack when you do. Then butter the crack and surrounding area with a light layer of JB Weld. Let it cure at least 12 hours before reassembling.
Post A Followup
: Re: Re: H oil pan leak
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
