Farmall Tractors Discussion Board |
Re: Disc brakes
Posted by Don Summers on January 29, 1999 at 17:07:47:
In Reply to: Disc brakes posted by john on January 29, 1999 at 16:15:32:
Take the housings to a machine shop and put them in a turning lathe and take a layer of glaze off all the surfaces that the brake pads come in contact with. Clean up the ramps that the balls work in, put in new springs, balls, and either replace the pads or take the glaze off them with a sander. Be sure to coat the balls lightly with grease when re-assembling. Put new rubber covers on the brake rods to keep out moisture, and don't let your tractor get wet! Hope this helps. I did a Super MTA and a Super W6TA and it worked for me. Good luck, Don Summers.
Post a Followup
