Re: head problems
Posted by The Red on February 12, 2001 at 03:47:57 from (12.75.197.233):
In Reply to: head problems posted by matthew whaley on February 11, 2001 at 23:14:05:
Matthew that tube is very important. It drips oil on the valve and rocker assemblies for lubrication.
To convert back to 6 volt, not much has to be done. If there is a resistor in the coil line, remove that or you won't have enough voltage going to the coil. You will need 6 volt light bulbs and of course the battery. More than likely the starter is the original 6 volt.
Post A Followup
: Re: Re: head problems
