Farmall Tractors Discussion Board
Re: Super A Transmission leak
Posted by Gman on January 29, 1999 at 18:52:20:
In Reply to: Super A Transmission leak posted by Ossie on January 29, 1999 at 18:40:16:
Ossie I restored a 130 which should be the same,block it up good and unbolt housing,and pull wheel and housing together. You will see the seal and replace it.Check bearing and hope it's not bad if it is I an't sure you can replace it without going in to the gear box
Post a Followup
: Re: Re: Super A Transmission leak
