Re: head problems
Posted by Theman on February 12, 2001 at 06:50:00 from (204.149.23.2):
In Reply to: head problems posted by matthew whaley on February 11, 2001 at 23:14:05:
The tube you are referring to is part of the crankcase ventilation system. There should be a small hole in this tube to assist in removing any blow-by past the valve guides. Oil returns to the crankcase by flowing down the push rod holes to lubricate the lifters. Air path through the engine should be as follows: Air is drawn into the tube on the tappet cover (right side of the engine and held in place by 3 cap screws) across the crankcase to the governor housing. You will see a little tube that runs from the top of this housing to the front of the head. There are threaded passages in the head that the fittings on the tube in question go into. Your tube pulls vapors from the valve cover area and they are dawn out of the back of the head and into the air cleaner. Now I wouldn't call this system PCV (Positive Crankcase Ventilation) but for late 1930's technology it isn't bad. On my '51 H I could put my hand over the air intake and enough air could be drawn through this system to keep the engine running. About all I can add to the 6 Volt conversion is to make sure the circuit is positive ground. Regulators are too expensive to learn this the hard way.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
