Farmall Tractors Discussion Board
Re: 1086hyd problems
Posted by RickB. on January 30, 1999 at 04:37:42:
In Reply to: 1086hyd problems posted by jkf on January 29, 1999 at 10:40:02:
Probably the seals on the lift cylinder are bad. Best thing to do is to remove the lift cover & replace all the o-rings & seals in the 3PH circuit.
Post a Followup
: Re: Re: 1086hyd problems
