Re: Tractor Tires
Posted by farmdog on February 12, 2001 at 19:35:44 from (207.177.72.139):
In Reply to: Tractor Tires posted by Terry on February 12, 2001 at 16:43:16:
I just removed Ca from my 400's tires...and replaced the rotted rims. It's nasty stuff.
To remove: pump up the tires, position the valve to the bottom, and remove valve stem. It will spray all over, and...uh...probably isn't environmentally friendly. When the valve blows air, you have to remove and replace the tube.
If you decide to leave the Ca in, keep an eye out for leaky valve stems; that's where it gets out and eats rims. Position the valve to the top (up) to keep the Ca in while replacing the stem core.
Good luck! Farmdog
Post A Followup
: Re: Re: Tractor Tires
