Re: FARMALL A HYD. RETRO FIT
Posted by Stan(VA). on February 13, 2001 at 19:06:53 from (207.172.180.114):
In Reply to: FARMALL A HYD. RETRO FIT posted by MNMAN on February 13, 2001 at 17:10:31:
You could try a 12VDC electric pump (provided you also update to a 12V battery and an alternator) I think Northern Tool sells them; or go belt drive if you can make up brackets for a PS pump from a local junkyard; or replace your engine block with one from a Super A or C with the factory pump and make a manifold that routes to your valve and reservoir; or go the simple route and trade your A for a Super A or a C that allready has the live hydraulics ;)
Stan(VA).
Post A Followup
: Re: Re: FARMALL A HYD. RETRO FIT
