Re: farmall H that won't run
Posted by ThatOtherGuy on February 14, 2001 at 12:58:50 from (206.157.110.212):
In Reply to: farmall H that won't run posted by Kevin on February 13, 2001 at 19:51:06:
My H ran out of gas and had trouble. Best thing is when it floods, push choke in and set throttle to full and crank it. It may take a while, sitting, like mine, to get it to start. And, check if the plugs are clean and have strong spark. You might need new points, or coil.
Hope this helps you out!
ThatOtherGuy
Post A Followup
: Re: Re: farmall H that won't run
