Re: Used Antifreeze Disposel
Posted by Glenn on February 15, 2001 at 05:28:04 from (199.196.144.11):
In Reply to: Used Antifreeze Disposel posted by Rod on February 14, 2001 at 22:55:13:
Don't pour it down the drain; most municipal sanitary sewer systems are not set up to handle antifreeze solutions. Call around to your local auto-parts stores and tractor dealerships to find one that will accept your used antifreeze. Often they will accept it at little or no cost to you. AutoZone is a great one for accepting used antifreeze, oil, etc. DO NOT dump brake fluid down the drain under any circumstances. If you think antifreeze is toxic(and it is), brake fluid is even worse.
Post A Followup
: Re: Re: Used Antifreeze Disposel
