Re: front pully on crank super AV
Posted by gene b on February 15, 2001 at 16:43:33 from (63.25.166.66):
In Reply to: front pully on crank super AV posted by Mike on February 15, 2001 at 16:28:54:
there is a set screw over the key use a three jaw puller some were tapped with a cap screw in the center i assume you have found this out the puller will do the trick have pulled 20 or so always use a three jaw type have made a bracket to use a hy jack to install be carefull
Post A Followup
: Re: Re: front pully on crank super AV
