Farmall Tractors Discussion Board
Re: I.H. 574
Posted by Harold H on January 30, 1999 at 13:43:28:
In Reply to: I.H. 574 posted by Herb on January 30, 1999 at 09:38:30:
Herb,
The International 574 was built 1971 - 1980 both as a International Standard and as a International Row Crop (not Farmall). It has a 3 13/16 X 4.390 200.3 cu in four cylinder engine. It tested in Nebraska test # 1098, 45.16 max db hp and 52.97 max pto hp. It should be more than enough tractor for your bushhoging and excellent for more. Worth depends on location.
Harold H
Post a Followup
: Re: Re: I.H. 574
