Re: Re: front pully on crank super AV
Posted by gene b on February 16, 2001 at 03:34:48 from (63.25.167.171):
In Reply to: Re: front pully on crank super AV posted by Mike on February 15, 2001 at 16:52:30:
heat will help also when reinstalling the pulley remember you have a new seal so that is why i made a bkt so i could use a small hy jack the heat sure would not do the new seal any favors check the surface on the pulley where the seal rides might need a sleeve over it if it is worn bad
Post A Followup
: Re: Re: Re: front pully on crank super AV
