Re: Super MD idle on gas
Posted by Haas on February 17, 2001 at 16:15:30 from (129.37.117.61):
In Reply to: Super MD idle on gas posted by Rocket on February 17, 2001 at 13:11:57:
As you know, there is no external control of fuel on the gas side, except the choke. To adjust the speed on the gas side, you have to remove the carburator. That is no easy task, as it is practically impossible to get a wrench on the front inside bolt (of the 4 bolts that hold the carb to the manifold). You can't get a socket on it, you can't get a boxend on it. You can get an open end on it and do about 1/8 turn or less each pull. Once you get it off, you will see a round plate on the passage where the air/gas mixture come out and goes to the manifold. To change the speed, you adjust that plate up and down. The manual calls for an open distance of 3/32 to 7/64 inch from the top plate of the carb to the plate. You also need to check that all the switchover stuff is working. The carb float is held up in diesel mode so that gas cannot flow to the carb. If that is not releasing properly on the gas side, that would limit the gas flow and cause you to have to use a lot of choke to suck gas in. Also, there are butterflys in the manifold that shut off the air flow through the carb in diesel mode, but are set to let air flow through the carb when on gas. If those are not working, you would not be getting enough air flow through the carb and again it would require choke to make up for it. Good luck, Let me know what you find.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
