Re: Stroker in super M
Posted by Les Repair on February 17, 2001 at 18:04:43 from (206.28.174.42):
In Reply to: Stroker in super M posted by RHINO on February 16, 2001 at 20:07:16:
If you put new sleeves and pistons and thet appeared similar to the ones you took out, you probably don;t have a M&W long stroke crank. I would think the crankshaft would have some markings on it.
Post A Followup
: Re: Re: Stroker in super M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
