Re: Re: Stroker in super M
Posted by 44M on February 17, 2001 at 23:12:35 from (152.163.201.212):
In Reply to: Re: Stroker in super M posted by Les Repair on February 17, 2001 at 18:03:12:
Hey Les, Could you tell me some of the particulars of the M&W stroker crank? How much stroke did it add? Did it come as a kit, ie crank,rods,pistons,sleeves,etc? And did the block have to be clearanced?
Thanks!
44M
Post A Followup
: Re: Re: Re: Stroker in super M
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
