Farmall Tractors Discussion Board
Changing Oil in a Super A
Posted by Stan on January 31, 1999 at 06:15:16:
What is the secret (if any) to getting a tight seal on the gasket for the oil cartridge. I used a Fram oil filter and it seems as though the gasket supplied was the exact same size as the case. If the two were not in perfect alignment when the tractor was started and the pressure came up it leaked badly. I did finally get a good seal but I've got to believe there is an easier way. Any help would be appreciated.
Post a Followup
: Re: Changing Oil in a Super A
