Re: farmall M 6 to12 volt
Posted by Dan on February 18, 2001 at 17:15:02 from (12.18.161.164):
In Reply to: farmall M 6 to12 volt posted by Ron on February 18, 2001 at 15:04:15:
You can use most any older delco as like S10 as they are smaller to fit under the hood and have internal regulator. If you need a wiring diagram check archives for a really good explanation of the complete changeover done by Bob M. If ya follow the instructions there you can't go wrong
Post A Followup
: Re: Re: farmall M 6 to12 volt
