Farmall Tractors Discussion Board
Re: Radiator Cap - Pressure or Not
Posted by TMAC on January 31, 1999 at 15:30:42:
In Reply to: Radiator Cap - Pressure or Not posted by Alan Hoover on January 31, 1999 at 14:22:26:
Alan; check your overflow pipe if it has one. If this Cub has a non-pressurized cooling system, the pipe will be inside the top of the radiator, below the cap. If so it won't matter what type of cap you use because boil-over and pressure is released thru the pipe and not the cap.
Post a Followup
: Re: Re: Radiator Cap - Pressure or Not
