Re: Light Dimmer Resistor Value
Posted by Bob M - what's happening to my reply text? on February 20, 2001 at 11:19:11 from (192.232.119.194):
In Reply to: Light Dimmer Resistor Value posted by Farmer Bob on February 20, 2001 at 08:03:17:
...previous reply text disappeared after posting twice. (System problem?!!) Will try once more:
Hey FB - I figured this info would come in handy sometime when I tucked it away in my Farmall electrical folder:
Posted by Jim becker on July 12, 1999 at 20:03:06 from (209.30.185.12):
In Reply to: R value? posted by Chuck Kaufman on July 11, 1999 at 07:51:46:
Light dimmer 5 ohms. Field resistance 2.8 ohms.
FB - Keep in mind the resistor needs to be rated for about 20 watts or higher - otherwise it'll burn up in use. Unlikely Radio Shack will stock something that big. But I've had success winding my own using a heater wire from one of the daughter's old hair dryers and a DVM. Hope this helps! ...Bob M
Post A Followup
: Re: Re: Light Dimmer Resistor Value
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
