Re: Re: Light Dimmer Resistor Value
Posted by Dave on February 20, 2001 at 13:01:54 from (128.113.83.131):
In Reply to: Re: Light Dimmer Resistor Value posted by Bob M on February 20, 2001 at 09:39:43:
If it has to take 20 watts then it has to handle 2 amps. (20 W = ohms X amps squared) You could use two 10-ohm one-amp resistors in parallel if two-amp resistors aren't available.
Post A Followup
: Re: Re: Re: Light Dimmer Resistor Value
