Re: Re: H motor smokes like crazy!
Posted by Mike on February 21, 2001 at 10:30:14 from (208.32.172.21):
In Reply to: Re: H motor smokes like crazy! posted by RB on February 20, 2001 at 18:14:03:
Thanks to all for comments. The smoke is blue, not black so I've got to figure it's engine oil. If the owner will let me run a compression check that should answer the question. I will look at the carb and timing to see if it's off. Any ideas what acceptable compression is? THANKS.
Post A Followup
: Re: Re: Re: H motor smokes like crazy!
