Re: How about a C or Super C
Posted by Haas on February 22, 2001 at 06:16:53 from (129.37.117.227):
In Reply to: How about a C or Super C posted by Bill C on February 21, 2001 at 19:19:19:
Both the C and the Super C have the hydraulic Touch Control. The fast hitch was an option on the Super C. All do not have it. You can buy an aftermarket 3 pt hitch for either. The Super C has a water pump (later Cs also had the water pump) and a larger engine. The C is bit underpowered I think, so if you are going to do real work, try to find a Super or at least a C that has been reworked with overbore sleeves and pistons. Some things to look for: Check the block behind the carburator. If cracked from freeze up, that is where they break out. Check the fan belt top pulley. It is made of stamped metal. You will find some worn out. That means the tractor has done a lot of work. Check for play in the steering. And check to make sure the grease fittings on the rear axle are in place and look like they have been used. The only lub the outboard rear axle bearing gets is from those grease fittings. The trans fluid does not lub that bearing. Also check that the transmission shifts good into all gears and is not making excess noise. Good Luck!!
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
