Re: Super A Carb...what model?
Posted by FC on February 23, 2001 at 06:39:04 from (63.80.243.2):
In Reply to: Super A Carb...what model? posted by Jeff on February 22, 2001 at 19:28:27:
I purchased a kit from the Case IH local dealer for my C which also had a Carter. I did not have the tag or any numbers either, but they were able to look it up. I also needed a float, but they said they were not available, I was able to repair and it so far has worked. This is probably a Carter UT model as that is what my C has. Good luck. FC
Post A Followup
: Re: Re: Super A Carb...what model?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
