Re: Re: F400 Governor Problem
Posted by Andy Martin on February 23, 2001 at 13:42:09 from (38.31.74.73):
In Reply to: Re: F400 Governor Problem posted by Dan on February 22, 2001 at 21:36:24:
Since you have condensation in the governer, I would suspect the tube from the governer to the carb also has some, and may be filled with water/oil mixture. Clean it out good.
Also, if the tractor sits a lot, put some alcohol into the gas tank. The throttle plate may be icing up on startup.
Post A Followup
: Re: Re: Re: F400 Governor Problem
