Re: special use of Farmall M
Posted by Haas on February 23, 2001 at 17:04:04 from (129.37.117.228):
In Reply to: special use of Farmall M posted by John on February 23, 2001 at 07:44:09:
The M does not have live hydraulics, and the lift all pump only puts out about 800 psi. That should be enough depending on the size cylinder you have. You will need a spool valve to control the cylinder, something the M does not normally have. The M normally only has single acting hydraulics. You would have to lock the lift all in lift mode and put the spool valve down stream in the pressure line from the lift all and run the return into the fill port of the lift all reservoir. If you get a super M with live hydraulics, it would be a different story. You would still likely need a spool valve added in a location handy for dumping.
Post A Followup
: Re: Re: special use of Farmall M
