Re: Farmall B what weight oil for transmission???
Posted by gene b on February 24, 2001 at 04:08:53 from (63.25.166.238):
In Reply to: Farmall B what weight oil for transmission??? posted by Matt Klarich on February 23, 2001 at 21:07:35:
you can drain then put some diesel fuel in and take on air hose stick it in the fuel use 20lb airpressure this will mix and clean aat the same time flush out see how it is colered this can tell if you need to repeatfill with any good 90wt gearlube
Post A Followup
: Re: Re: Farmall B what weight oil for transmission???
