Re: Best way to clean our unused threads in the transmmssion case.
Posted by George on February 24, 2001 at 06:16:49 from (207.75.138.33):
In Reply to: Best way to clean our unused threads in the transmmssion case. posted by gibby on February 24, 2001 at 05:30:15:
Gibby,
If I understand you correctly, it sounds as if you didn't get a large enough/correct diameter tap if you are not getting the threads to clean up.If your problem is not getting threads to go deep enough in to the hole because the tap is tapered at the tip you can #1, get a bottom tap or#2, grind off the taper on the end and make it a bottom tap ...... hope this helps Geo.
Post A Followup
: Re: Re: Best way to clean our unused threads in the transmmssion case.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
