Re: farmall M fluid capacity
Posted by The Red on February 24, 2001 at 07:36:36 from (12.75.198.94):
In Reply to: farmall M fluid capacity posted by rw on February 24, 2001 at 06:54:34:
RW the M crankcase holds 8 quarts. SAE 30 will work for temperatures above freezing. If you are speaking of the belly liftall hydraulic pump, it holds 6 quarts of either non-detergent SAE 30 or you could use Hytran or Hygard. The transmission capacity is 13 GALLONS of 90W. Don't forget the air cleaner cup. It holds about a quart of SAE 30.
Post A Followup
: Re: Re: farmall M fluid capacity
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
