Re: cloudy oil
Posted by The Tractor Vet on February 24, 2001 at 16:39:12 from (216.196.12.187):
In Reply to: cloudy oil posted by les on February 24, 2001 at 16:21:46:
Sounds to me that you are getting water in it ,check the coolant level and see if the level is going down and only use 30 weight oil not a multi grade like 10w30 .I don't think that it is condencation,you may have a head gskt. leaking or even worse a cracked head or block ,hope not for your sake.Do you let it set out?, if so make sure that the exhust pipe is coverd so as not to get rain water in the engine.
Post A Followup
: Re: Re: cloudy oil
