Re: cloudy oil
Posted by big fred on February 24, 2001 at 20:52:00 from (208.51.245.89):
In Reply to: cloudy oil posted by les on February 24, 2001 at 16:21:46:
If you are meaning cloudy as in "dirty", I would ask you if you recently switched from non-detergent to detergent type oil. If so, your oil may be dissolving sludge accumulated throughout the years and holding it in suspension. You will need to continue changing oil and filter every few hours until the engine is cleaned out. You can hasten this by removing the oil pan and rocker cover and manually cleaning those areas, as most of your sludge will have accumulated there. If it is cloudy as in "milky" then you are getting water in it somehow.
Post A Followup
: Re: Re: cloudy oil
