Re: Timing Super A
Posted by gene b on February 25, 2001 at 18:21:32 from (63.25.166.194):
In Reply to: Timing Super A posted by Raymond Jeffreys on February 25, 2001 at 10:46:09:
double dot on dist drive goes on the double dot on camgear then the single dot on cam goes tto single dot on crank all at the same time the rotor should be pointing at no 1plug wire if rotor doesent line up with no1 mag is off 1/2 turn if that still doesent line up you must have had the mag apart and the teeth on the rotor drive arent lined up if you havent had the mag apart everything should be ok I WOULD TURN THE ENG9NE OVER A FEW TIMES TO CHECK EVERYTHING NOW IS THE TIME BEFOR THE FRONT COVER IS ON
Post A Followup
: Re: Re: Timing Super A
