Re: My H's Weight
Posted by Denny Frisk on February 26, 2001 at 06:04:19 from (12.4.181.2):
In Reply to: My H's Weight posted by 1PWRFULH on February 25, 2001 at 19:24:12:
I have a modified FORD loader on my Super H. From YEARS ago the bare tractor with rear fluid & 1 set of weights weighed 5250#. Fluid weight depends on tire size of course. 11 X 38 is the same as 12.4 X 38 and hold about 550# each if calcium chloride is used at maximum recommended concentration. So My bare tractor weight is about 3850#. Your tractor should be similar. I have plenty of weight on the back to handle the loader. I used it a couple yrs ago to move crushed rock. I could get the bucket heaping full, 40" wide X 36" long bucket heaped full. It did steer kinda hard. For most Non-loader uses it doesn't steer that much harder with the loader. Just run your frt tires really hard - High air pressure.
Post A Followup
: Re: Re: My H's Weight
