Re: MD Wire Harness question
Posted by Haas on February 26, 2001 at 06:21:46 from (129.37.117.6):
In Reply to: MD Wire Harness question posted by Ike in NC on February 25, 2001 at 17:11:26:
If you have a "regulator" mounted on the radiator, likely someone has changed things around, because that is not where it was originally. I think a 52 MD would have had a regulator and not the cut out. The wiring on the MD is not all that complicated and I don't think you need to bother with a harness. Just go to a generator shop and get a new regulator and mount it same place the old one is. Make sure the shop knows it is for a 3 brush generator. Then you run two wires to the generator, one to "field" and one to "Gen"(or armature) terminal. Then run one wire from the "Bat" terminal on the regulator to the ammeter. If the regulator has an "L" terminal, that is for "load" or "lights" and does not need to be connected to anything. The other side of the ammeter should go to the battery. It may be just connect to the starter switch on the battery side. Then polarize the generator by jumping a wire momentarily from the armature(or may be called gen) terminal to the battery terminal on the regulator. If you buy a new regulator there should be a paper in the box explaining all this. Be carefull not to short out any terminals or ground anything accidently or you can ruin the regulator or the gen or both. Since there is only one wire to run from the regulator to the ammeter, it's not really worth a wiring harness. This is what I did to my MD and it works fine. I used two 6 volt batteries on mine connected in series just like they came originally. Post a picture of your MD if you can, I would like to see it. Good luck! I have the instruction sheet from my regulator and could scan and Email to you if you want.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
