Re: M Radiator Question
Posted by The Red on February 26, 2001 at 13:31:41 from (12.75.196.143):
In Reply to: M Radiator Question posted by Willie on February 26, 2001 at 11:28:56:
Willie if the neck on the radiator flares out like the neck on a car or truck, then you will want a pressure radiator cap. Around 7 to 8 PSI if I recall correctly. If the neck looks like the neck on your gas tank, then a gas cap type of cap should be used. Temperature range of 160 to 180 is fine. More than likely you have a pressure type radiator.
Post A Followup
: Re: Re: M Radiator Question
