Re: H CHARGING PROBLEM
Posted by Bill C on February 26, 2001 at 18:48:31 from (209.143.29.220):
In Reply to: H CHARGING PROBLEM posted by JDHUMP on February 26, 2001 at 18:29:58:
You have to polarize the generator to the battery. Take a piece of electrical wire(insulated) and put one end on the one terminal on the LEFT side of the voltage regulator,take the other end of the wire and put it on the CENTER terminal on the RIGHT side of the regulator. Do this for just a second,a spark will happen,this is normal,don't touch any other terminals on the RIGHT side or you will fry the regulator!!!$35. I put a new regulator on my 51 H this past summer,that info was on a paper in the box,did that and haven't had a problem.
Post A Followup
: Re: Re: H CHARGING PROBLEM
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
