Re: H CHARGING PROBLEM
Posted by KS on February 26, 2001 at 20:52:04 from (24.25.105.151):
In Reply to: H CHARGING PROBLEM posted by JDHUMP on February 26, 2001 at 18:29:58:
Did you put a new regulator on when you went through the generator? If so you need to polarize it as Bill C states in his message. If you left the original cut-out regulator on, dont forget you need to turn the light switch to the first (L)or second (H) setting to get a load on the generator to make it charge.
Post A Followup
: Re: Re: H CHARGING PROBLEM
