Re: Re: Re: Re: Lead substitute - use it or not.
Posted by dick on February 27, 2001 at 07:47:07 from (63.120.111.98):
In Reply to: Re: Re: Re: Lead substitute - use it or not. posted by the tractor vet on February 26, 2001 at 19:17:17:
Actually, I think you've got it partially backwards. The higher octane fuels contain more of the lighter components in crude oil and fewer of the heavier components. The lighter components tend to ignite at lower compression ratios than the heavier components (such as iso-octane), which make them unsuitable for use in high-compression, high-performance engines where they ignite prematurely causing engine knocking. Most if not all antique tractor engines have LOW compression engines, which don't require high-octane gasoline to prevent knocking - I believe many of these engines were originally designed by IH to use gasoline with octane ratings as low as 70. However, the heavier components in higher octane gasoline generally will contain a higher carbon-to-hydrogen content ratio than that in lower octane gasoline. Carbon generally will produce more heat when burnt than hydrogen will, so the higher octane fuels should burn a bit HOTTER than the lower octane fuels, although probably not all that much. Plug fouling tends to be reduced by hotter plugs, or activities which produce more heat in the engine (such as plowing), and thus your observation of less plug fouling when using higher octane fuel is consistent with the higher octane fuel burning hotter than lower octane gasoline, and not the other way around.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
