Re: H hydraulics + 3-point hitch
Posted by Red Raider on February 27, 2001 at 10:55:45 from (192.105.235.146):
In Reply to: H hydraulics + 3-point hitch posted by Charles on February 27, 2001 at 05:18:43:
I have an H with one two-way cylinder with the pressure side connected to the left rear hydraulic pump port of the liftall. The return side has the hose attached, but is not connected to anything. No auxiliary valves or anything else, and for some reason I can lift and hold position on my drag shreader while operating for hours with no leak down, and still push the control rod all the way forward to release all pressure and the shreader will drop.
third party image
Post A Followup
: Re: Re: H hydraulics + 3-point hitch
