Re: electronic ingnition
Posted by Bob on February 27, 2001 at 18:23:31 from (207.177.94.204):
In Reply to: electronic ingnition posted by ksk on February 27, 2001 at 09:33:52:
ksk: If you haven't already done so, I would suggest you install a new condenser and try that for your point problem before you go to the expense of an electronic ignition system. You will have to change to a negative ground system if you install the eis. Let us know - OK?
Post A Followup
: Re: Re: electronic ingnition
