Re: Re: repair m
Posted by danny on February 27, 2001 at 19:57:15 from (207.160.4.176):
In Reply to: Re: repair m posted by RB on February 27, 2001 at 17:32:39:
I have all the gears out of the rear exept the gear at the end of the shifting gear shaft.There is two differnt areas.The very back with axle gears and stuff then the front area with shifting gears.Well in between the two areas there is a bearing that the shifting shaft goes through.The retaining ring on the shaft will not come out and seemes to have alot of presure on it.The reson for all of this work is the motor will turn over but the rear end will not.It looks to like the bearing at the front of the shifting shaft is in a bind because with tractor in nutral the shifting shaft should turn free but wont move.So the main gear and bearing by the clutch houseing needs to come out to slide the shifting shaft forwords instead of tring to take it out towords the back of the tractor.
Post A Followup
: Re: Re: Re: repair m
