Re: Question on plowing.
Posted by Dirttracker on February 27, 2001 at 20:17:17 from (192.206.56.1):
In Reply to: Question on plowing. posted by gibby on February 25, 2001 at 20:19:25:
Narrow front ends always pull when the right rear is down in a furrow, most of the front weight is on the right front tire, the left tire is almost off the ground or at least much lighter than the right , also make sure both rear tires have the same amount of calcium, I learn the hard way myself, the lighter tire spins much easier, kind of weird until you figure out whats causing it.
Post A Followup
: Re: Re: Question on plowing.
