Re: Wiring Diagram 100 Farmall changeover to 12 volt
Posted by Bob Burke on February 28, 2001 at 03:12:42 from (216.182.20.77):
In Reply to: Wiring Diagram 100 Farmall changeover to 12 volt posted by Tim H. on February 27, 2001 at 18:59:28:
I have a lick for you. www.ytmag.com/articles/artint195.htm . This is a great way to convert a tractor, if you have a starter soliniod instead of a pull type you just have to run another wire from the keyswitch to the sol. Make sure the sol. is not 6v only
Post A Followup
: Re: Re: Wiring Diagram 100 Farmall changeover to 12 volt
