Re: Super A trannsmission oil
Posted by Haas on February 28, 2001 at 05:32:18 from (129.37.117.99):
In Reply to: Super A trannsmission oil posted by Ricky on February 28, 2001 at 05:15:49:
If you are talking about the plug on top of the transmission near the gear shift, that is the fill plug and not for checking level. The level plug is located on the left side near the front of the transmission. If is behind the brake rod on that side and you may have to take the brake rod loose to get to it. The transmission level should be up to the bottom of the hole when the plug is out. When filling the transmission fill it until oil comes out the hole. If you are changing the transmission oil, you can use either 90w transmission oil or HyTran tractor fluid. I don't know the capacity, since I don't have a Super A anymore. The 90w will be cheaper and will work fine. If you change the fluid in the hydraulic unit, use HyTran tractor fluid. Also, the Super A has a final drive for each wheel that is not connected to the transmission. Each of the final drives must be filled and checked separately from the transmission. The plugs for these is under the tractor near where the drawbar fastens to the tractor. The level should be up to the bottom of the fill plug. There is not a drain plug for the final drives. To drain the final drives, you have to remove the pans that cover the bull gears. If you decide to remove those, go buy some gaskets at the IH dealer before you do it. Hope this helps.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
