Re: Need input re: 384,484,584,684 Utility Tractors
Posted by AGEN on February 28, 2001 at 14:21:37 from (128.194.22.55):
In Reply to: Need input re: 384,484,584,684 Utility Tractors posted by Mike K on February 28, 2001 at 12:01:05:
Hello Mike K. My Dad and I have a 684 International. It is an excellent tractor. We used to use it to pull a round baler until recently. We also plow with it and pull a disk, as well as feeding round bales in the winter. Starts a little hard when its slightly cold. Usually requires choking and/or ether to get it going. This could be troublesom in the North. (We are in southcentral Texas) Also, it has occationally gotten stuck in one range (that is High, Low, or Reverse) This requires taking the cover off and using a screwdriver to pry it out of gear. I am not sure it would make a great loader tractor, as shifting between Reverse and High/Low is sometimes tough. This is assuming of course the tractor you're looking at is a gear and not a hydro model. Overall, our 684 is a good machine.
Post A Followup
: Re: Re: Need input re: 384,484,584,684 Utility Tractors
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
