Re: 3 GALLONS OIL/ANTIFREEZE OUT OF PAN FROM H
Posted by Andy Martin on February 28, 2001 at 14:36:26 from (38.31.74.52):
In Reply to: 3 GALLONS OIL/ANTIFREEZE OUT OF PAN FROM H posted by LOU on February 28, 2001 at 14:27:12:
Sounds like the wrong head gasket to me, running oil directly into the push rod cavity.
You don't have wet sleeves do you?
I'd drain it again, and if no water, check to see if someone's been messing with you. If you find water, I'd leave the drain plug out and put water in. If some drips out, pull the pan and you'll see where it is coming from.
Post A Followup
: Re: Re: 3 GALLONS OIL/ANTIFREEZE OUT OF PAN FROM H
