Alternator conversion
Posted by Ron on February 28, 2001 at 15:35:15 from (208.31.4.179):
I just finished converting my Farmall 230 to 12 volts.I used a 3 wire 63 amp Delco.The problem is I can't shut the motor off with the ignition switch.The #2 Terminal is wired to the Bat.terminal .Bat terminal is wired to one side of the amp meter from the amp meter to one side of the ignition switch.The other side of the ignition switch goes to #1 terminal and to the coil.The other side of the amp meter goes to the starter.Does anyone have a fix for this problem.
Thanks in advance for your help.
Post A Followup
: Re: Alternator conversion
